I use it. I'd guess being able to do without is handy in a clutch problem situation, but I can't see it being good for the bike in the long run. or at least not as good.
You just said because you never tried, I was curious if there was more to it. I have never tried clutchless up or down. Probably because I am to chicken to stall out and wreck.
Oh, ok fair enuf... When is time to up shift, i l just barely lay my heel on the lever and let off throttle. It shifts on its own as if I used clutch.. It's easy, fast.. Believe it or no, easier on the bike.. I didn't invent the technique..
Downshifting is different acuz I rev match so it's not the same thing,,, maybe it is,, I've never tried.. For the reasons I said
