Evo or Twin...which should I keep?
Old 04-13-2016, 09:16 AM
Speedjester's Avatar
Speedjester
Speedjester is offline
Default Evo or Twin...which should I keep?
Well I have two RK. One a carb 96 EVO with 30k miles in mint condition...the other A 05 with 28k miles also in great condition.... Here is my dilemma. I can only ride one at a time... I live on a dirt Rd so I keep my 96 and the wife's Heritage at another property I own...The 2005 just sits in my garage at home.... Haven't ridden it in 4month...So im thinking of getting rid of one....Only problem is I'm not sure which one to keep..... There both beautiful bikes... The Twin cam has a lot more get up and go...but from what I understand the EVO is easier to work on... On the flip side.. Parts might be tough to find for the 96...
Any thoughts and opinions would be appreciated...
Old 04-13-2016, 09:22 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
Ride each one for about an hour back to back and see which one gives you the bigger smile.
Speedjester (04-13-2016)
Old 04-13-2016, 09:39 AM
E8USMCRET's Avatar
E8USMCRET
E8USMCRET is offline
Veteran: Marine Corp
Received 20,256 Likes on 6,547 Posts
I'd keep the carbed EVO in a flash.
Old 04-13-2016, 09:45 AM
StoneyFatBoy's Avatar
StoneyFatBoy
StoneyFatBoy is offline
You know these bikes work on dirt roads right ? Keep the 05 it's already at your house
Old 04-13-2016, 09:46 AM
TroubleHead Fred's Avatar
TroubleHead Fred
TroubleHead Fred is offline
Received 1,962 Likes on 1,160 Posts
Carbed Evo, without a second thought. Parts for the Evo are as easy to find as they are for the twinkie.
Old 04-13-2016, 10:04 AM
RHPAW's Avatar
RHPAW
RHPAW is online now
Received 15,172 Likes on 6,711 Posts
Unless the '05 has had the tensioners serviced or updated already, it's about to cost you money. Keep the Evo...it doesn't have those issues.
Old 04-13-2016, 10:11 AM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,633 Likes on 1,628 Posts
evo, hands down. no tensioners to worry about. the evo has better wheel bearings, better primary tensioner. the evo can be hopped up alot cheaper than the twinkie and will last just as long if not longer. inner cam bearing and base gasket are the biggest issue but are a cheap fix.
Old 04-13-2016, 10:32 AM
Speedjester
Normal dirt road no issue ... But I have 1 mile of mostly sugar sand... Front end sinks right in....
Old 04-13-2016, 10:34 AM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 49,934 Likes on 19,376 Posts
Yep ... I'd lean towards the EVO too ... If it was something that I was going to keep "forever" ... There are days when I wish I had my 1992 FLHTCU back .
Old 04-13-2016, 10:46 AM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,075 Likes on 2,558 Posts
I'd toss a coin...
Quick Reply: Evo or Twin...which should I keep?
