Inexplicably Disappearing Oil from Engine
I seem to have a major mystery on my hands and no idea where to go with this. I seem to be losing oil from somewhere and not sure what the cause. I haven't rode the bike much cause of the prior issues I had but when I did it was less than 250-500 miles total in 2 weekends. The bike sits in the garage during the week. However I seems to be losing 1/2 to 1 qt every 2 weekends.
Here is the checklist:
- I know it's not smoking out of the tailpipe,so doubt it be a ring issue.
- I have checked the air filter to make sure it's not blowing it out through the intake or carb. Checks clean.
- Checked the primary for extra oil. Nothing there out of the ordinary.
- There is no leaks on the garage floor so doubting the gaskets anywhere is leaking where visible.
- The bike does have 60 to 65k miles,not sure if that helps.
You can burn oil without it being detected (blue smoke) out of the pipes, at 65k I think you're probably just burning it off, assuming you have no leaks worn rings or valve guides would be the cause.
One way to slow it would be using a heavier grade oil, personally if I had 65k on my motor I'd more than likely run straight 50 weight but that's just me.
Another possibility would be sumping, when oil drains into the crankcase..There's a lot of threads on that.
Yes I do he's 3 years old and sometimes runs off with keys.
If you check the oil after its warmed up and before the oil is allowed to run to the sump, you'll get a more accurate indication.
I always fill it up to the 3/4 mark max, ...any higher and it tends to spit oil out the breathers.
Didn't think of that one. I usually check before I take it out but never thought of checking when I put the bike up.
