RPM range help
RPM range help
90% of the time I ride, my RPMs are between 2,000 and 3,000. Sometimes below 2,000; rarely if ever above 3,000.
I have a tuner and tuned a map to the bike. I think it runs great, but I'm a newb.
Is this OK? Am I doing something wrong? Isrunning it only in this range detrimental to the performance or longevity of the bike?
Thanks for your help.
Most everyone will say to keep them above 2,000. I do, as long as I'm giving it gas. As for shifting, I do that mostly by sound. But it's rarely much over 3,000.
Some might say it depends on the bike. I don't know, since I don't know if they're geared different. I'm not that knowledgeable in that area.
Just turned 90,000 on my 07 Ultra. Most of the time I run between 2,000 and 3,000 rpm. In sixth gear at 75 mph its turning 2800 rpm. But, in a high speed pass (to avoid trouble) or a short on ramp to freeway speeds, I will take it to 4,000 or more. It really begins to haul the hay above 3,500 rpm. The redline is 5,800 rpm, so the only thing I consider is below 2,000 rpm. I will loaf along down to around 1800, and maybe gently accelerate from there in third or fourth gear but no higher gear than that. Based on 50+ years riding.
