Have an 06 FLSTC and am changing out rear fenders....Does anyone know how to get fender tip light wire out from under the back fender brace without cutting wire? Plug won't go under brace...have tried to pry brace up with screwdriver but no luck...Also have same problem running harness thru rubber conduit with plugs on harness...Suggestions anyone?
I think you need to get the individual wires out of the connectors. Service manual shows using a safety pin to depress tangs inside connector so each pin / wire comes out.
