what to use for cable lube?
Old 05-04-2007, 08:11 PM
user 37474839's Avatar
user 37474839
user 37474839 is offline
Default RE: what to use for cable lube?
I read somewhere (maybe on here?) that it's really not necessary to lube the cables on the newer bikes..anyone else heard this?
Old 05-04-2007, 08:17 PM
bay13's Avatar
bay13
bay13 is offline
ORIGINAL: celtlion
Good point, I've wonder about this myself. I know on Cars, The Volvo at least, up till 1998 they all had cable drive and they are never lubed, it's not a maintenance item. The Bike cables work fine in the housing it's in, they are not lubed from the factory. The lube doesn't make them work any better. Maybe it's a rust prevention thing?
Old 05-04-2007, 08:30 PM
pococj's Avatar
pococj
pococj is offline
Received 1,297 Likes on 484 Posts
My throttle cable isn't lubed. It rides in a plastic (teflon?) sleeve. I do lube the clutch cable, usually with an old solution of graphite in alcohol I made up.
WD-40 isn't a very good lube. OTOH, it's a great Water Displacer.
Old 05-05-2007, 07:49 AM
Jehu's Avatar
Jehu
Jehu is offline
Received 1,114 Likes on 626 Posts
I just use alittle bit of synthetic gear lube as I typically have it handy. I keep meaning to get a cable dedicated lube but never seem to get aorund to to it - so the gear oil it is.
sparkdawg
General Topics/Tech Tips
08-27-2009 12:38 PM
oscarmeyers69
03-31-2008 11:28 PM
oscarmeyers69
03-31-2008 01:50 PM
04 rkcrr
02-08-2008 12:48 PM
blown alcohol
03-18-2006 10:50 AM
Quick Reply: what to use for cable lube?
