Tail lights
Old 08-31-2015, 11:34 PM
_Gir_'s Avatar
_Gir_
_Gir_ is offline
Wife and I both sport BAL-1s. Never, ever going back to stock or even HD LED.
Old 09-01-2015, 10:57 AM
frankegd's Avatar
frankegd
frankegd is offline
Custom Dynamics has a module that is plug $ play for the '14 and up with CAN bus. It'll let you configure the cycles, lengths and won't flash if the turn signal is on.
The flashes are nice, and are becoming more and more the standard on cars too. If someone follows you, and says it is annoying, well - mission accomplished... You've seen me!
I hope that helps.
Thank you
FrankEGD
Old 09-01-2015, 11:31 AM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is offline
Originally Posted by mikelikesbikes
Negative. Nowhere near as bright as BAL.
Just squeeze your brake lever harder.....
OP did say LED that flashed. If you have LED's and you modulated your brake pedal or lever it would flash.
Old 09-01-2015, 12:17 PM
hillbillywhisperer's Avatar
hillbillywhisperer
hillbillywhisperer is offline
I have the module that only flashes the tour pak lights. I have it set to Flash 3 x's twice and then stready.
Old 09-01-2015, 12:22 PM
E8USMCRET's Avatar
E8USMCRET
E8USMCRET is offline
Received 20,256 Likes on 6,547 Posts
Check out Custom Dynamics, they have a wide selection of LED's from front to rear.
Old 09-01-2015, 05:41 PM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
I hope that helps.
Thank you
FrankEGD
Annoying is one thing. Confusing is another. I don't want the car behind me to be confused at all. I want him to know exactly what I am doing.
Old 09-01-2015, 05:53 PM
MikeBel's Avatar
MikeBel
MikeBel is offline
Received 1,564 Likes on 671 Posts
Originally Posted by StoneyFatBoy
You know you can get the same effect from stock tail lights by tapping the brakes a few times then grabbing and holding them in
Yea but the big difference is you are releasing your brakes with each and every tap. With the BAL or similar, brakes stay applied while the lights flash. In an emergency stop do you really want to be releasing your brakes?
Old 09-01-2015, 06:19 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is online now
Received 4,770 Likes on 2,533 Posts
I've had my BAL save me twice at a light, while I was stopped. The first time a pickup was screeching up behind me, already in my escape route, he stopped so fast a second pickup rear ended him. And that's how they drive here. I have no pity on drivers who rush up on me, they're going to see the light. The air wing luggage rack on the Road Glide Ultra has an integrated LED brake light in it. BAL low, luggage rack high.
Harleygirl81
2014-2023 Touring Models
25
05-30-2015 06:07 AM
TODDNVAL
12-22-2013 03:56 PM
BackwardsJ
05-16-2012 01:02 PM
elauee1
08-12-2011 09:39 AM
rhaneski
04-05-2009 08:58 AM
Quick Reply: Tail lights
