Security pin #
Security pin #
So my father in - law bought a used 14 ultra trike from a dealer with 1200 miles. It is a repo and still under warranty. The original owner changed the security pin so dad takes it to the dealer to have it re-set and they tell him it can't be done. I call BS. If it is true I would expect them to replace the module. He's passive and won't fight for it. Says he'll just carry both fobs and a spare battery.
Has anybody else run into this?
Changing the PIN To maintain security, the rider can change the PIN at any time. Refer to Changing the PIN.
STEP
NO.
ACTION
WAIT FOR CONFIRMATION
NOTES
Select a 5-digit (1 thru 9) PIN and record on the wallet card from owner's manual.
With an assigned fob present, turn the OFF/RUN switch to OFF.
Turn the ignition switch to IGN.
Cycle the OFF/RUN switch twice: RUN - OFF - RUN - OFF - RUN.
Press left turn signal switch 2 times.
ENTER PIN will scroll through the odometer window.
Press right turn signal switch 1 time and release.
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
Enter first digit of new PIN by pressing and releasing the left turn signal switch until the selected digit appears.
The new digit will replace the current in odometer window.
Enter second digit of selected PIN by pressing and releasing the left turn signal switch until the selected digit is present.
11
Enter third digit of the selected PIN by pressing and releasing the left turn signal switch until the selected digit is present.
Press right turn switch 1 time and release.
13
Enter fourth digit of new PIN by pressing and releasing the left turn signal switch until the selected digit is present.
14
15
Enter fifth digit of the new PIN by pressing and releasing the left turn signal switch until the selected digit is present.
16
17
Turn the OFF/RUN switch OFF, then turn the ignition switch to OFF.
Pushing the OFF/RUN switch to OFF stores the new PIN in the module.
https://www.harley-davidson.com/cont...rs-manual.html
Changing the PIN
STEP
NO.
ACTION
NOTES
11
13
14
15
16
17
