Fuel
Fuel
Okay first... I do use 91 octane fuel which is the highest octane I have around here. That said, Why do we need the higher octane fuel and if it is better then why do they even offer lower octane fuels at stations? And a friend asked if he could run e85 in his Harley I told him no but I am not sure. Also should I get something to boost octane if I have to fill up with a lower rating (a few stations around here only carry 89)
Higher octane fuel isn't higher quality, it can just be squeezed more before it blows up. Higher compression engines need to run higher-octane fuel so it doesn't combust prematurely. That said, modern fuel-injected engines are able to detect and compensate for fuel that is lower octane than recommended - meaning you can run 87 without a problem.
EDIT: And to answer your question, lower octane fuel is carried because most vehicles run on engines with low compression ratios, which actually run better on 87 than 91. If you put a high octane fuel in a low compression engine, it won't fully combust and you'll have fresh gasoline going out the exhaust.
