Fuel
Old 06-22-2015, 03:01 PM
Thumper09's Avatar
Thumper09
Thumper09 is offline
Originally Posted by DMWyant
Okay first... I do use 91 octane fuel which is the highest octane I have around here. That said, Why do we need the higher octane fuel and if it is better then why do they even offer lower octane fuels at stations? And a friend asked if he could run e85 in his Harley I told him no but I am not sure. Also should I get something to boost octane if I have to fill up with a lower rating (a few stations around here only carry 89)
They offer 3 different octane ratings for people who are dyslexic. Some people look at a certain combination of numbers and see some other combination of numbers. To help minimize this, they put 3 series of number combinations to help minimize the chance that at least people with this disease will be able to see one of them.
  #32
Old 06-22-2015, 04:22 PM
Reindeer's Avatar
Reindeer
Reindeer is offline
91 octane, ethanol free when possible.
  #33
Old 06-22-2015, 06:51 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,987 Likes on 17,898 Posts
Originally Posted by Markymannn
We have both 93 & 94, both with ethanol. The 91 only used to be E free, but not any more. I use the 93/94, figure it costs me maybe $2 a tank, so what
I'd kill for easy access to 94, this crap they are passing off as 91 out here is a joke.
  #34
Old 06-22-2015, 07:25 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
I run 87E10 unless I am in over 4,000 ft. elevation (Sturgis) then I use 85. I run the 87 in a 750, 1 883, 3 1200's, 2 TC88's, 3 previous 96's, 1 96, 2 103's, 2 103 HO's, 2 110's. All run strong and with a combined 30,000 miles a year none have ever pinged from ocean to ocean and from Key West to the Arctic Circle.
I do run iridium plugs, SE wires, less restrictive breather and stock exhaust. I treat the bike at 3,000 miles with Techron to remove combustion chamber build up. I used to mist water but Techron does the job with less work.
HD motors are low compression and long stroke push rod motors. Unless you increase the compression and install a high over lap cam, higher octane is a waste and in fact will foul the engine more and CAUSE pinging.
With that said I do only run 93 in my 13 Street Bob with the 120R in it. Once I get 3,000 miles on it I will see if I can drop down to 91 and then 89.
  #35
Old 06-22-2015, 07:47 PM
wwiiavfan's Avatar
wwiiavfan
wwiiavfan is offline
Received 1,154 Likes on 505 Posts
I run 93 all the time, or 91 at least if 93 isn't available. Mostly because I like running 6th gear at 60 mph and up.
  #36
Old 06-22-2015, 09:22 PM
NoCoLoco's Avatar
NoCoLoco
NoCoLoco is offline
I use mid-grade in my TC96 stage 1. If it was completely stock I would use premium just because of how lean and hot they run. I wouldn't use regular unless I had no other choice... even then I would put in just enough to get me to the next station haha!
  #37
Old 06-23-2015, 10:33 AM
galtjunk's Avatar
galtjunk
galtjunk is offline
I run as high an octane rating as I can get.
The bike will run on regular but it performs better on premium.
One of my cars has a 2 liter 300 horse 4 cylinder. You can really tell the difference in octane with that motor.
  #38
Old 06-23-2015, 12:46 PM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
Interesting. I haven't seen 94 since Sunoco use to carry it as their ultra. That has been quite a few years.
  #39
Old 06-23-2015, 08:47 PM
streeteagle's Avatar
streeteagle
streeteagle is offline
Originally Posted by 13dino
One doesn't have to be a paying member of AMA to support their being. They're an essential Watch Dog group supporting motorcyclist, who all should be aware and supportive of. Just sign into their email and learn what the gov is pushing through that needs to be addressed with rebuttal for obvious reason.
The lobbyist that introduced w/o challenge, sustain and progressively voice increased Ethanol mixture into gasoline is just an unbelievable example.
http://www.americanmotorcyclist.com/...orthought.aspx
This is just one example of what the AMA does for us which some may not be aware. We direly need an advocate for motorcyclists like the AMA.
If you're not a member, please join. They have a really good mag also.
  #40
Old 06-23-2015, 09:05 PM
opr1945's Avatar
opr1945
opr1945 is offline
Originally Posted by DresserDude
Uhhhh, E85 is 85% Ethanol and 15% gas. That would be a DEFINITE "no".
I believe it is actually the reverse......E85 is 85% gas 15% ethanol.
Quick Reply: Fuel
