Blue Loctite for Pegs and Shifter Peg?
Old 04-25-2007 | 07:53 PM
Unamed's Avatar
Unamed
Default RE: Blue Loctite for Pegs and Shifter Peg?
Ok after reading these posts, ill stick with blue, is more better with locktight?
Old 04-25-2007 | 11:40 PM
Blackbird's Avatar
Blackbird
I use Blue Loctite on my pegs and shifter.
Old 04-25-2007 | 11:45 PM
Wally's Avatar
Wally
ORIGINAL: Unamed
No, one drop in the right place is all you need.
Old 04-25-2007 | 11:49 PM
sl3slinger's Avatar
sl3slinger
if you use red youll need to heat it up if you want to get it back apart, blue should work just fine in your application
Old 04-26-2007 | 12:21 AM
badherb's Avatar
badherb
if you have a knucklehead, shovel, or a pan then use red... other wise blue or just a lock nut or lock washer will be fine.
Old 04-26-2007 | 10:50 AM
Sammi's Avatar
Sammi
Blue it is.
Thanks for all the info.
Sammi
BobbyJones
06-01-2017 11:30 AM
hallfleming
06-26-2015 05:34 PM
gsxrboy96
03-29-2012 03:10 PM
gunner11
02-08-2009 12:40 AM
Bluerose
07-05-2006 01:12 AM
Quick Reply: Blue Loctite for Pegs and Shifter Peg?
