How are the apes affect twist
How would the apes will affect twisting
Hı all
I have drag bars on my se st 2014
And ı do make fast twists and turns with them and they feel very good
İf ı change them with apes will i loose that good cornering capacity
Or putting apes will not change a thing
Thanks
Thanks
Had a friend with apes on his Low Rider who had no problem hustling it through the twisties...but that was what he was used to. Might take you some time to adjust. Try it...you can always change 'em back. Remember...you'll have less weight over the front tire (one of the reasons for clip-ons and leaning forward...weight on the front tire) and you'll have moved your CG backwards. Take it easy until you adjust...
It depends how higher they are and your over all position on the bike. I have 16 on mine. I keep them pulled back. They're below my shoulders and kind of fall into my hands. My overall handing, slow speed and grinding through the turns, is way better than with the stock bars. But that's my set up, not yours. It's all about setting them up for your comfort and riding style.
