Bar Snake?
04-21-2007, 12:45 PM
Bar Snake?
Has anyonever heard of or tried this product. It's supposed to cut down on the vibration in the handlebars.My shovelhead buzzes so bad at high RPMs, and it's hard to hold on to above 70mph. If it works this would be a good idea.
http://www.barsnake.com/
04-23-2007, 09:25 PM
RE: Bar Snake?
I guess you can't use one of those if you want to hider yer wiring in the bars?
04-23-2007, 09:27 PM
RE: Bar Snake?
Make sure the rubber bar mounts are in good shape...
04-23-2007, 09:40 PM
RE: Bar Snake?
is a bar snake part kin to a lounge lizzard.......sorry...had to do it.....I have seen them at the shows, but never rode anything with them on it.
04-24-2007, 12:33 PM
RE: Bar Snake?
I used one on a Fatboy I had years ago....surprisingly enough they work.... just make sure you get the right diameter for your bars
04-24-2007, 05:04 PM
RE: Bar Snake?
used one on my fxr, it worked ok. It did not work as well as the std vibration dampners that bolt on to the end of the bars. I know they don't look right on a HD, but they worked better than the bar snake.
04-24-2007, 05:37 PM
RE: Bar Snake?
Thanks for the input, I'm probably gonna give it a try, they are pretty cheap.
MikeRC
08-25-2019 07:02 PM
BuzzCap7
"The Florida Crew"
06-20-2019 09:00 PM
ChickinOnaChain
05-01-2014 04:04 PM
eisterd
The General Motorcycle Forum
31
04-25-2010 03:10 PM
