SERT Install
RE: SERT Install
You will have to buy a serial to USB adaptor if your computer/laptop doesn't have a serial port. Other than that its pretty easy. Just take your time when flashing the ECU. FYI, thedyno tuner said that even the map I loaded was on the lean side.
RE: SERT Install
ORIGINAL: FACTION95
STeve
RE: SERT Install
No I'm sorry he didn't mention exactly where it was lean. I would guess the whole map was lean. I still have some decel popping so I posted the same question as to should I bump up the values on the CLB tables. The response was bumping the CLB would not fix the problem. Its eliminated by raising the values in the other tables. Your best bet would be to have it tuned out while on the dyno.
