power commander LCD display unit
RE: power commander LCD display unit
Quite a few of them on the racetrack now. You cannot build a custom map on the fly with the LCD display, but you can select between two different maps, and it also displays useful parameters such as RPM and throttle position. It does not display map values. You would still need to hook up the PCIII to a PC or laptop to access the mapping software and build or display a map.
Always keep shining!
OK, from the ad, you can adjust map on the fly.
Shining Display is specialized on LCD advertising players, with ten different classical designs including all standard sizes from 7inch to 55inch for your choosing. Moreover, Shining is always willing to be your "production base", offerring support on various requirements for all kinds of projects, whatever in software or hardware. Our aim is to make your design idea become reality.
*golf clap*
Very nice, your first post is to drag a four and a half year old thread from the grave and kick it around. It's dead Jim!
albngore
01-02-2012 07:44 AM
