broke the tip off a torx bit
Old 04-15-2007, 03:40 AM
vertigo14's Avatar
vertigo14
vertigo14 is offline
Default broke the tip off a torx bit
Pfft wtf
I broke the tip off a craftsman torx bit tryn to pull off the sideplates ofa sissybar. I got 3 of the torxs off but the 4th one busted a cm off the tip of my torx bit.
Hmmm
Bleh this set cost a bunch...30bucks
Red Locktited this torx screw.
Old 04-15-2007, 03:51 AM
YUCK's Avatar
YUCK
YUCK is offline
Default RE: broke the tip off a torx bit
bummer,,,,hammer chizel,,,try and just tap on the torxs,,,oppsite direction it broke,,,if that don't work,,,chizel a small grove in the side of the button head,,,then tap the button hear counter clock wise.....us the hammer and chizel,,to try and turn the bolt,,,not cut it off!!!
Old 04-15-2007, 03:55 AM
vertigo14's Avatar
vertigo14
The bolt didn't brake, nor did I strip it....
I broke the tip off the torx tool... the bit haha
Maybe craftsman will replace it for me.. isn't there a lifetime warranty on them tools?
Old 04-15-2007, 03:57 AM
74_ironhead's Avatar
74_ironhead
74_ironhead is offline
Snap-On warranties their's, I'm on my 3rd T-40 in 2 weeks [&:]
Old 04-15-2007, 04:06 AM
vertigo14's Avatar
vertigo14
I own 3 snap on tools.. a sweet torque wrench which cost me like 350 dollars heh.. gosh snap-on tools are expensive LOL.. like Flukes are..
and I got a set of deep standard sockets and regular sockets (not 12 point)
But anyways most of my tools are craftsman and since I have never broken a tool, wonder how you get them to replace a part in a set...
Old 04-15-2007, 04:12 AM
hartick's Avatar
hartick
hartick is offline
just head to your nearest sears and show them the piece. if they have it you will be walking out with a new bit. my experiences have been good with sears. i took back 2 of their craftsman flashlights. put them thru the wringer on my sub, then took them back for new ones.
Old 04-15-2007, 04:40 AM
user 37474839's Avatar
user 37474839
user 37474839 is offline
I've broken off a few cheap torx bits before also..it's pretty easy to remove them since it's weak anyway, I just take a small nail or thin punch and tap it center..it will usually disintegrate and you can take a set of needle nose pliers and pull the pieces out.
The real solution is to get a good set of torx wrenches or bits..the good one don't break off like the cheap Chinese stuff.
Old 04-15-2007, 04:45 AM
vertigo14's Avatar
vertigo14
Oh I see what he ment...
Yeah the little tip of the torx bit wasnt too deep, so it just fell out when I turned the sideplate upside down.
But it was my only tip of that size...
I am gona go to a real tool shop on monday.. not sears and see what they can offer
Old 04-15-2007, 04:51 AM
Rhubarb's Avatar
Rhubarb
Rhubarb is offline
Are craftsmen made in china now?
Wow, I'll have to look at mine.
I've returned tons of tools over the years and never had an issue. They just give you a new one. Even if they have to open up a set.
Old 04-15-2007, 05:02 AM
grunt's Avatar
grunt
grunt is offline
Craftsman replaces any damaged tools - even if you did it yourself. I got a new std screwdriver after I ground the tip to a point to punch out a stripped bolt.
Quick Reply: broke the tip off a torx bit
