broke the tip off a torx bit
Old 04-15-2007, 05:27 AM
vertigo14's Avatar
vertigo14
vertigo14 is offline
Default RE: broke the tip off a torx bit
ORIGINAL: grunt
Craftsman replaces any damaged tools - even if you did it yourself. I got a new std screwdriver after I ground the tip to a point to punch out a stripped bolt.
Haha Grunt [sm=funnypostabove.gif]
Old 04-15-2007, 07:20 AM
edilgdaor's Avatar
edilgdaor
edilgdaor is offline
Received 6,612 Likes on 3,880 Posts
I ran over a Craftsman Screwdriver with a car and chipped the tip. Barely. They gave me a new one, after I told them how I did it.
Does anyone make torx bits for an impact driver ?
Old 04-15-2007, 08:48 AM
bay13's Avatar
bay13
bay13 is offline
ORIGINAL: vertigo14
I own 3 snap on tools.. a sweet torque wrench which cost me like 350 dollars heh.. gosh snap-on tools are expensive LOL.. like Flukes are..
and I got a set of deep standard sockets and regular sockets (not 12 point)
But anyways most of my tools are craftsman and since I have never broken a tool, wonder how you get them to replace a part in a set...
You take the tool to the store with you, walk up to a register and tell them you would like to have These broken craftsmen tools replaced.
Old 04-15-2007, 09:02 AM
mid_life_crisis's Avatar
mid_life_crisis
mid_life_crisis is offline
ORIGINAL: edilgdaor
Snap-on , Mac, Matco have them or they used to
wayne
Old 04-15-2007, 09:08 AM
onephsyco1's Avatar
onephsyco1
onephsyco1 is offline
I have both , Craftsman & Snap on .
They all break ! And while they both
do free replacement of the broken ones .
It dosnt help at the time while you are in the
middle of A job !
I am A Ford Tech . I wish they would just do away with them !
If the torx bolt is real tight ( Hard to turn) Some times just tapping on the head of the bolt helps . But A little heat can
be your best friend , For freeing up locktite or even severly
rusted bolts !
Jack
Old 04-15-2007, 09:27 AM
cHarley's Avatar
cHarley
cHarley is offline
I also broke a Craftsman torx bit removing a side plate screw. Went back to Sears & they gave me an entire new set no questions asked.
Old 04-15-2007, 09:33 AM
dastark's Avatar
dastark
dastark is offline
Red locktite is some strong chit. Used it on my fender struts for bag brackets. Figured stronger is better. Untill I tried to loosen it up. [:@]Next time blue it is. (In the appropriate application, of course.)
Old 04-15-2007, 10:02 AM
jimb's Avatar
jimb
jimb is offline
I wouldn't use red loctite on a sissy bar sideplate.If you're going to take stuff off and pit it back on I'd use blue.I rarely use the red.I have Craftsman and Mac and as stated above, they all can break
Old 04-15-2007, 11:47 AM
JeepMaker's Avatar
JeepMaker
JeepMaker is offline
I hate Torx bolts. I was changing the brakes on my sons Grand Prix GTP and twisted aTorx tip. Big sucker too, IIRC it was like a 62.
Old 04-15-2007, 11:48 AM
skateboard's Avatar
skateboard
skateboard is offline
take it back to sears,I've broken ratchets and never had a problem exchanging them there[/align]
[/align]
Quick Reply: broke the tip off a torx bit
