Frame Lock
Frame Lock
Just found the ultimate transportation system for the Harley.
click thumbnails for larger picture
[IMG]local://upfiles/17429/D0E569E0F85F44D9AABBDD4A653653B6.jpg[/IMG]
[IMG]local://upfiles/17429/6F80E2B804464C70842D2B190859780E.jpg[/IMG]
[IMG]local://upfiles/17429/A808C1B3689E47A1807FE4D860E59386.jpg[/IMG]
Anyone have this system in use?
I need two of these for the enclosed trailer.
I know I know, ride it don't haul it. . . .
Still nice to have a support vehical along during a trip.
RE: Frame Lock
I,m not to sure how that thing mounts to the bike but in that second picture it sure looks like that thing hangs way too low.If that bar with the two holes in it where the pin goes through stays on the bike your in for some problems the first time you lay that bike over in a turn.Unless that part comes off somebody is gonna get hurt!
RE: Frame Lock
s&s makes it...there are two small black machined pucks that clamp permanently to your frame rails ...as you ride up in the trailer and center the floor mount, slide the pin thru and ractchet (it has a cam closure i believe) the bike to lock position...i like the setup, a friend has em in his trailer...they're high tho
RE: Frame Lock
Hmmmmm, maybe OK, but I'd sure want to see one with a big bike locked in it first and then test the side by side torque that is going to all occur at two very small points on the frame, by test pushing the bike side to side. All the rocking stresses are occurring so low to the ground vs. the much higher center of gravity rocking back and forth that it just seems that is too much stress in two little spots not intended by MOCO.
harley0711
12-10-2007 11:51 AM
