Using heated liner without jacket
Old 10-12-2014, 07:17 PM
rob0225's Avatar
rob0225
rob0225 is offline
Default Using heated liner without jacket
Anyone use the heated liner without a jacket? If so, does it still work pretty well?
Old 10-12-2014, 07:20 PM
ngshop's Avatar
ngshop
ngshop is offline
No, it needs something to cover and block the wind.
Old 10-12-2014, 07:23 PM
Shep68's Avatar
Shep68
Shep68 is offline
It works so/so w/out an over-jacket and depending on temps. The panels are spaced apart under the lining and those are the heated areas; IOW the entire surface area of the jacket does not heat. So if the temps are cold enough you will feel some cold where the panels are not located. No biggie if it's 50; more so if it's 30.
128auto's Avatar
128auto
128auto is offline
I have Gerbing jacket liner, I wear it under vest all the time, my sleeve are still warm. It might be a little warmer with jacket on top. Both work!
Old 10-13-2014, 12:50 AM
cdestuck's Avatar
cdestuck
cdestuck is offline
Veteran: Marine Corp
Gerbing will tell you that theirs is not made to wear as outer ware. They sort of imply that it's not made to take the wear of the wind. At the price of it, I keep mine covered.
Old 10-13-2014, 05:54 AM
rob0225's Avatar
rob0225
rob0225 is offline
Yeah I'm just talking about those in-betweener days when a jacket on top is a bit much.
Old 10-13-2014, 08:21 AM
DanRC's Avatar
DanRC
DanRC is offline
Then you probably do not need a heated liner, just a warm jacket.
Old 10-13-2014, 10:55 AM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Jacket Liner
Don't you have a controller for it ? Wear an outer jacket and turn the controller down or off if it gets too warm.
pondscum (10-22-2019)
Old 10-13-2014, 12:41 PM
patrickd's Avatar
patrickd
patrickd is offline
They don't block the wind.
Old 10-25-2014, 05:25 PM
From_Behind's Avatar
From_Behind
From_Behind is offline
Who cares?
Quick Reply: Using heated liner without jacket
