Is there a easy way to oil the clutch cable?
Old 09-29-2014 | 07:54 PM
old Shakey's Avatar
old Shakey
Stage III
Default How do you measure main drive gear end play
Took down my 78 shovel to fix oil leak on main drive gear. Little mixed up on how to do the end play ck. Took chain sprocket off seal and spacer. May-be
have left spacer and seal in. .125 is my end play. way off
Old 09-29-2014 | 08:10 PM
05flhtbob's Avatar
05flhtbob
I lube the clutch cable once a year with a thick oil and also all pivot points and it pulls about as easy as the 14's hyd clutch
Old 09-29-2014 | 09:49 PM
ZUTEDUFF's Avatar
ZUTEDUFF
You could plug the vent tube on the tranny and ride it until oil comes out at the clutch handle, then remove the plug and add more oil to the tranny....
Old 09-30-2014 | 12:28 PM
Old Road Toad's Avatar
Old Road Toad
Originally Posted by dgoodbmw
I am pretty sure your clutch cable is teflon lined and requires no lubing. If you can see a white tube like cover on the cable do not oil it, it doesn't help. If you have to oil, i suggest you do not use DRY SLIDE as it cakes up at the bottom and makes clutch pull much harder than it should be. been there done that, nuff said
+1 on not using DRY SLIDE on teflon cables, just about locked up my cable on a trip. Lucky an HD dealer in Portland Or. was close, cost me $50 to get that crap cleaned out.
Old 09-30-2014 | 01:01 PM
Crazy Biker's Avatar
Crazy Biker
My local dealer sells this stuff.
Old 09-30-2014 | 05:18 PM
dibe's Avatar
dibe
Old 09-30-2014 | 05:25 PM
Jackie Paper's Avatar
Jackie Paper
Believe you are correct with the lining from what I have read (all bets off with aftermarket and such)...Mine at 40K have never been lubed. All you are going to do is crude it up. If it ever gets tight, replace it at 100K.
Old 09-30-2014 | 05:42 PM
cHarley's Avatar
cHarley
+1 - The newer cables (since 2009??) have a visible (white) Teflon liner and are not supposed to get/need lubrication. If you feel the need to lube one of these, I wouldn't use anything other than Dri-Slide.
wideglideCVO
Engine Mechanical Topics
03-21-2022 09:15 AM
JuanderBoy
10-30-2019 11:23 AM
Hundred Dollars
02-14-2012 09:01 AM
bdjhog
06-14-2011 11:41 PM
softail04
09-03-2008 02:16 PM
Quick Reply: Is there a easy way to oil the clutch cable?
