Jackpot head pipe HTC Ceramic coating info
Jackpot 2/1/2 stainless steel head pipes are now available with an optional HTC ceramic coating. We are using an exclusive multi step process that includes seperate coatings internally and externally for the best overall results. The external coating is a sterling ceramic finish that not only looks stunning it is also very durable, the internal coating is a compound designed to retain heat in the exhaust stream instead of absorbing it into the exhaust system which allows for maximum scavenging, together these coatings allow for up to 30% lower surface temperatures over an uncoated pipe. This pipe offers the ultimate in construction and heat reduction over the factory system and works with the OEM heat shields. We also offer a lifetime warranty on our head pipes. Here are a few pictures
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
