2010 FLHRC map
2010 FLHRC map
Hello,
I have a 2010 FLHRC, V&H Dresser Duals, with their Fishtail II slip ons, Screamin Eagle "ventilator" performance breather, and a PC V. I am currently using the canned M15-011-023 map and the bike is running pretty good,, any suggestions on dialing it in to my specific set-up? I haven't seen any other local bikes using the "ventilator" but can't imagine there aren't a 1000 guys out there with the exact same setup... any help would be greatly appreciated.
Thank You!!!
Thank You!!!
I would use the running quality, throttle response and performance as the determining consideration for the accuracy of your tune. You have not stated there are any issues and the bike is running well so the map you are running should be fine. We generally do not use the Dynojet maps, however if you would like to try something different I would give map -017 a try as it should also work well.
Sorry, for the late response. For technical questions please direct them to jamie@fuelmotousa.com
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
billybobber
03-19-2010 09:07 AM
