2002 rk pcv map questions
2002 rk, True duals v&h, Rinehart slip on, stage 1, se a/c. PCV retrofit
Question#1- Which map would be best?
Question#2- When loading a map do I need to disconnect from the cpu first?
Question#3- Before downloading a map do I need a number or something to be allowed to download? Thanks Cass
We have a specific map for this setup on our database, you can use the fuel map page on our website to request the map. You do not need to disconnect the unit when changing maps. All you need to download the map is the software and the map you want to load. You can contact us with any additional questions and there is also a helpful PC-V user guide here http://www.powercommander.com/powerc...tml/wwhelp.htm
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
