O2 sensors
On factory O2 sensor equipped bikes with the PC you will use O2 eliminators. Because the factory sensors can only measure a small are near 14.6:1 and only provide feedback when they are switching and in closed loop, they cannot be used when you require a AFR richer than 14.6:1 with these products.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
When the o2 sensors are left in on 2010 bikes will the become bad over time due to being inactive inside the headpipe. thanks
This should not be a problem with these narrowband sensors. There can be issues with Wideband sensors if they are left unpowered as a it uses a driver/controller to maintain the pump cell and control voltage to prevent overheating, but a narrowband sensor does not use this logic and uses constant voltage to get the sensor up to temp much faster. On our 2010 Touring model we have unplugged the sensors with PC-V during our R&D and also re-plugged back in while testing some other products with no issues.
