FXDXT fork seal change question
I have the FXDXT (T-Sport) with a leaky fork seal. The forks have the adjusters on them and the manual says to replace seals I need to, after unscrewing the top cap, remove the springs with a special harley tool. Then I can remove the bottom bolt to pull the sliders off. Then to reassemble, to reset the adjusters and then attach the springs again. Why can I just uncap, drain, unscrew bottom bolt remove sliders, replace seal and reassemble without removing the spring from the top cap?
Spazz
2014-2023 Touring Models
53
01-08-2018 11:49 PM
