07 rk rotors switched sides
I just noticed the left front brake rotors are switched left is on the right side and right side is on the left the tire rotation is correct I bought the rk used so maybe some one else switched them anyway will this make a difference should I switch them back ? thanks
btw these are wire spoke 16 inch rims I have a 17 inch rim and tire off of a st glide and the rim size that's stamped into the rim is on the left side of the rim and the rim size that's stamped on my rear rim is also stamped on the left side . the front 16 wire rim size is stamped on the right side but the directional arrow of the new front tire is going in the correct direction
if that helps any
if that helps any
if that helps any
if that helps any
There should be an arrow on the sidewall of your tire somewhere that indicates the direction of travel.
yeah the tire is mounted in the right direction I made sure of that when I put the tire and rim back on the bike and the correct spacers are where they are sposed to be . so all I have to do is switch sides with the rotors ok easy thank you. it will not hurt any thing running the hub in reverse from the way it rotated before ? in any case ty guys
Jackie Paper
09-17-2014 05:39 AM
