Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Setting tire pressure do you go by the sidewall or whats in the book?
Old 03-23-2007 | 10:20 PM
Twincam Dave's Avatar
Twincam Dave
Default Setting tire pressure do you go by the sidewall or whats in the book?
I go by sidewall of tire, how bout u ?
Old 03-23-2007 | 10:27 PM
thrillseeker's Avatar
thrillseeker
Default RE: Setting tire pressure do you go by the sidewall or whats in the book?
actually I go bymy dealers recommendation 40 rear, 32 front.
If it weren't for that, I would go by the book.
Old 03-23-2007 | 11:22 PM
Cornhusker's Avatar
Cornhusker
Book most of the time.
Old 03-23-2007 | 11:44 PM
tbone52's Avatar
tbone52
book
Old 03-24-2007 | 01:18 AM
piniongear's Avatar
piniongear
Sidewall only.
The motor company does not make tires, the tire company does. So they know best and label their tire to that spec....................pg
Old 03-24-2007 | 02:07 AM
Sharknose's Avatar
Sharknose
If 36 front/40 rear is printed on the sidewall or manual, then that's what I follow.
Old 03-24-2007 | 02:10 AM
DougsDyna's Avatar
DougsDyna
06 SuperGlide........ 34 front
44-48 rear (Metzeler)
DougJ (not Bob)
Old 03-24-2007 | 11:47 AM
soup48's Avatar
soup48
On the sidewall it is mostly to air the tire up for mounting purposes. I usually go by the book.
Old 03-24-2007 | 01:19 PM
mwdguy's Avatar
mwdguy
ORIGINAL: soup48
Wrong, the sidewall is where you should always look for proper inflation numbers for that tire. As piniongear said the tire company makes tires not the MOCO.
Old 03-24-2007 | 01:31 PM
jaxdwg's Avatar
jaxdwg
I use to keep my pressures at about 30 psi front and rear (for the softer ride)but was having cupping problems so I went to 36 front and 40 rear. Now the tires last much better and I don't get the cupping and it is about what is recommended, live and learn for me, but hey, it's all good----jack
Quick Reply: Setting tire pressure do you go by the sidewall or whats in the book?
