HD wide tire kit
RE: HD wide tire kit
Save your money. Just take the fender mount bolts and turn them around so the button head is on the inside and put an acorn style nut on the outside. With this you can mount a 150/80-16 with no problems. I did it to my 01 FXSTS and had no problems even after I lowered it. H-D's kit with the offset spacers and brake caliper will move the tire to the right a 1/4 inch but guess what, you'll still only ba able to mount a 150 tire. Anything wider then that and you have to cut the frame struts off and go with an aftermarket kit.
