Shorter shocks = how much less ground clearence
Thanks, with 11" shocks it should be about 6.4", which will work for me.
The reason I'm asking is when i look up the specs for the 2004 FXDXI it says the ground clearance is 5.9 with the stock 13" shock. When i got down there with a ruler it was more like 7". Using the 1.7 figure it's 7.6, lol. confusing.
Not sure on the ground clearance... Read your first post wrong. Dividing by 1.7 will give you the distance from the bottom shock bolt to a place directly about the bolt and inline with the top mounting bolt. Imagine your shock making a right triangle with the rear fender strut. Maybe that accounts for the difference in your measurements. Also, I.m just guessing on the angle.
