Belt tension without the gauge
Does anyone know the recommended allowable travel for the drive belt on my Deuce? I don't have the Harley gauge to apply 10 pounds of tension to it.
On most bikes, you aim for 1/2" of play (13mm) in the chain.
Does anyone have the correct setting for this? This is my first adjustment on a belt-drive bike (just changed rims). Or will I need to bite the bullet & get a gauge?
TIA,
Cannon
TIA,
Cannon
RE: Belt tension without the gauge
Take the belt in mid span, and twist with your fingers as hard as you can.
Aim for 45 degrees from horizontal, any less and it's too tight, any more and it's too loose.
I've never had any problems doing it this way from the belt jumping or slipping (too loose) or whining (too tight).
ORIGINAL: 1FLTRI4ME
Why not spend the $25 so you dont have to guess?
ORIGINAL: xxxflhrci
I bought that gauge and don't use it. I doubt it is a precise instrument anyway. The twist thing works as well as just learning the feel of what a 10 gallon jug of milk feels like on your finger...
ORIGINAL: 1FLTRI4ME
Ever get a titty-twister? No two are alike!
ORIGINAL: Jonny Cannon
If you don't abuse your belt by doing frequent hole shots or power shifts I would think you would be fine with the twist test, as I did with my old bike.
