Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
2012 SG rear shocks
Old 11-24-2012 | 06:41 PM
ronherman's Avatar
ronherman
Question 2012 SG rear shocks
on my 2012 SG the suspension in the back just sucks! i am looking into maybe new rear shocks, i have looked at the progessive and the olhins and both are quite pricey. i read an article somewhere about changing the oil in the shocks that it helps. i am looking to find a reasonable way to do this without breaking the bank. any suggestions from any one? Thanks
Old 11-25-2012 | 06:43 AM
grbrown's Avatar
grbrown
You own a 2012 SG? Ohlins are NOT pricey! They are pocket money. Phone Howard at HDF sponsor Motorcycle Metal and talk things through with him. He offers members a decent discount and will custom build shocks to suit YOU. It's the only way to travel. Do it once, do it right, otherwise you will be messing around for ages.
Old 11-25-2012 | 06:54 AM
Iceman24's Avatar
Iceman24
Curious, have you tried changing air pressure settings in your 2012 FLHX rear shocks?
Old 11-25-2012 | 06:37 PM
CROCKETT's Avatar
CROCKETT
I had an 09 roadking with air shocks, just traded for 2013 roadking cvo and what a much better ride. i would change the air shocks for the premium shocks, big difference in ride!!!! But then again, there might be a better than what i have now....
Old 11-25-2012 | 08:12 PM
ronherman's Avatar
ronherman
yes i have changed the air to different pressures, still not riding to well. i am looking at the progressive 940's. the cost i found was under $500. but still looking, need to make a couple calls tomorrow and go from there. thanks every one
Old 11-26-2012 | 12:47 PM
ronherman's Avatar
ronherman
ok i had a small leak on the right shock at the fitting and the shrader valve was a little loose, that explains alot! set at 35psi hopefully no leak down now, time will tell. it rode much better than before with both of us on the bike.
Old 12-03-2012 | 04:05 PM
09B29's Avatar
09B29
i am thinking using the 2013 CVO shocks on my 2012 SG
Old 12-03-2012 | 06:01 PM
y2kflhr's Avatar
y2kflhr
The price difference between a set of progressives or the HD premium shock and the ohlins/jri's is a couple of hundred, amortize that over a couple of years or better yet per mile and the cost difference is nothing, the ride difference is Night and Day!!! spend the money and get the best
Old 02-06-2013 | 08:14 AM
Midnight Rambler's Avatar
Midnight Rambler
I recently changed the stock air shocks to CVO shocks on my 09 SG because of a blown seal, and they cannot be repaired. Harley wants $250 for one air shock, and $275 for both. Not happy with the CVOs'. $560.00 I feel I wasted. They are very stiff, and on bad roads with pot-holes you sometimes feel like you have no shocks at all, and thats on the softest setting. I purchased a set of the stock air shocks off ebay for $130 and put those on. Ohlins seem a little pricey, but you have to ask yourself, what is a nice ride, and good handling worth to you.
Old 02-06-2013 | 06:10 PM
sftdyna's Avatar
sftdyna
just get progressive 944 shocks and be done! there 530.00 delivered and are as good as anything ive ridden. I recently rode my friends cvo street glide and the premium shock wasn't bad, it was way better then my street glide air shocks but still lacking. last night i stopped by his house and low and behold he had put the 944's on his cvo. He told me after ridding my bike he couldn't go back to his set up, and the premiums aren't bad so believe me if you bite the bullet you will be pleased. Im currently using the hd spring and am very pleased but may try the lighter one soon.
Quick Reply: 2012 SG rear shocks
