Wheel Balancing
It is essential tire/wheel assemblies be balanced before use and rebalanced each time the tire is removed or replaced. Unbalanced tire/wheel assemblies can vibrate at certain speeds, and tire wear will be greatly accelerated.
All Dunlop street tires should be installed with the yellow balance dot at the valve. Wheels may be balanced with spoke nipple weights, lead wire or self-adhesive rim weights. Consult the motorcycle manufacturer for approved wheel weights.
Dunlop does not recommend the use of dry or liquid balancers/sealers and will not warrant tires into which these materials have been injected. Tire and wheel assembly balance must be checked with a balance stand or computer wheel balancer.
Source: Dunlop Tires
