Rear brake not working properly
'07 Superglide. Had to replace the rear tire and in doing so due to a case of dumba$$ on my part I took apart the brake caliper. Got everything together and bled the brakes using Dot4 brake fluid per procedure in the manual. Took for a test ride and brake didn't work correctly so came back and bled it again and got a couple more bubbles out but still will not lock up the rear brake under hard braking. It will slow down but not like before. Could it be because I got brake fluid on the disc and pads or something else? Have gone through about 8 oz. of brake fluid bleeding system. Using Prestone Syn Dot4 brake fluid. Help please. Just learning how to wrench on these so excuse my lameness.Thanks in advance.
