Cutting fork springs??
Has anyone ever cut the fork springs on their scooter? I know with a car you can cut however many ring off and the springs will still function properly. I am looking at lowering the front end of my ride, but I am also trying to do it without the least amount of purchased parts. I have lowered the rear 1 1/2 by removing the rear shocks and installing metal rods. I would like to lower the front the same amount. Any help would be appreciated.
Thanks,
Phil
Thanks,
Phil
RE: Cutting fork springs??
No, it won't work. You'll just make them a little softer, but won't lower the bike. Loosen up the triple tree clamps and move the fork tubes up. Depending on your risers, you can get about 1" lower that way.
If you want more, you'll have to disassemble the forks completly, and place a spacer deep inside, under the damper tube.
Of course, if you shorten it, you will lose some suspension travel. For the first inch or so, that's usually not an issue. But more than that and you'll have to add stiffer springs to compensate.
ORIGINAL: hogwyld79
Thanks,
Phil
Thanks,
Phil
The safest way to do this will also cost you some money. Buy progressively wound springs. They will be shorter than your stock springs and come with pcv spacers that you can cut down to bring the height of your front end to where you want it. Being progressively wound, they wont bottom out and you will retain good handling.....................BG
Progressive makes a lowering kit for around $100. You can get a good deal on this kit at Motorcycle accessory warehouse. You can do this on line or give them a call. They have the best price i have found. I have used a few of the progressive springs and I like em'
ADRENALINE RUSH
04-24-2015 05:33 PM
