Rake,Springer length &wheel size??
Hello guys!! Needing some advice on Rake, fork length and wheel size.
I`ve seen a nice custom bike i like the look of, its got stock length down tubes, 38deg rake, its front end is a stock length springer,with a 21" wheel.
Im looking at starting my own project in my Garage{2 kids under 3 and a full time wife living with me} so im prepared to spend a few years in there!!.
im liking the look of the 38 deg rake,but id like to use a 2under springer with a 23" front wheel {18"rear},does anyone see any problems with this?? is rake to much at 38?? will there be any ground clearance issues, frame sitting front end low/high etc?? any info would be great,pictures of project with similar sizes would be awsome,
Thanks for your time,
El Gordo.
El Gordo.
Seems to be the best place to start & if the time is there then all you should need to do is figure out what is wanted & stay with it. Because tire diameters change & those changes could affect any frame setup the tires/wheels are a great place to begin. But, if there is a frame already modified & built in the picture you may want to measure the clearances it will get by the dimensions you're wanting to work with. I think the best way to start & get a good visual is to get some butcher paper & draw it all up with the dimensions reduced to fit the paper (suggest 2 pieces about 9' x36" taped to make 9' L x 72" W, should get you really close to the actually size of the bike); this is probably going to help any builder you may interact with that is going to help with some of the hard parts, too.
cherry1873
03-10-2012 06:42 AM
