1986 rubber mount frame
You can see parts lists for your frame on Ronnies H-D website, also take a look at 1990s engines, which are probably the same. They will let you see the parts you are missing.
The rear mounts are concentric with the swingarm spindle, which is mounted off the rear of the trans casing and the front mount uses a bracket to rest on a rubber cushion. You will need a stabilizer at the front, also a bracket and stabilizer between the heads.
You would be well advised to find an Evo dresser and study it closely, to get a good idea of what you are letting yourself in for! There is no certainty the Indian S&S is entirely compatible with a Harley frame, but S&S themselves can probably answer that for you.
Tim Jitsu
General Topics/Tech Tips
10-18-2015 04:03 AM
Tim Jitsu
10-17-2015 11:56 AM
