i want to try a 16 inch wheel on my dyna, any suggestions?
well i think that would depend on a couple of things. the actual size of the 16 inch tyre and the fact my fork tubes are already lowered 3/4 of an inch in the trees as it is.
i dont think trail is reduced exactly the same as the height of the front axle. i imagine there is some triangular relationship, but you are right in that it would result in less trail. how that would effect my ride, i do not know.
The 16" wheel and stock '05 Fat Boy Dunlop tire is 25.25" from tread to tread. Tire profile plays a role. Sometimes those bigger wheels use a lower profile tire. I prefer the road feel of the taller and wider front tire on the 16" rim. It just feels more connected.
RIGHT ON!
Aftermath, measure twice...right, right, right.
26 1/2"(non-inflated). A Dunlop D404 (3000mi), 130/90-16 is 25 & just under 1/16th".
Funny how all of that matters because a 38 degree neck angle becomes 35 degrees at a length of 35" = (roughly) 30/16"--your frames neck angle is built by the connecting frame tubes but is determined by an intersecting plane.
The rest of the frame's tubes determine how weight is distributed (so to say).
Good lookin' out.
the dunlop 404 sounds like the better tyre for my likes.
as far as getting used to what one rides. i have had my dyna since new, may of 2008.
i just never really got used to it. the front end just feels tall and top heavy. my ankle rebels against the weight when stopped. it always feels like it wants to flop on me, and it actually has once. very uncool.
i never felt that way on any softail or shovelhead 4speed frame w/boards.
Change is good
Depending on what tire you get, you will need to lengthen the forks by 3/4" going to a 19" pizza cutter to some 16" tires. Remember that the radius of the tire determines how long the forks must be. Go with a 49mm fork and wide glide type trees such as a FatBob as all of the parts are already available. A 1 5/8" fork is not the best choice, heavy & too much deflection. I hate the handling and stability of my 19" and I am going to put on a wide glide set of C/F wheels and 16" tires.
The Dyna has a pretty tall stance doesn't it, compared to the Shovel's & Soft tail's?
I usually set my seat height somewhere in the 24" area just above the knee, & then carry my motor a little higher than most in my style at 7" or so.. But I use a 4 banger motor & use no oil can gives me a little leverage sitting lower, because I never liked the taller ride height having to extend my legs so much was uncomfortable, wobbly, sort of feeling.
i will look at the fatbob front ends to see what can be swapped with my bike. what is 1-5/8" in metric? what is C/F wheels?
i sure will like to see how you make these changes. thanks.
