Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
front end
Old 04-08-2011 | 12:54 AM
wray's Avatar
wray
Stage II
Default front end
the front end will shake almost like hide speed wobble in the forks I checked the tripple tree for correct swing and pinch bolts any suggestions
Old 04-08-2011 | 04:04 PM
Old Gunny's Avatar
Old Gunny
head bearings loose?
Axle bolts?
Wheel bearings.
Better check all the front end.
Old 04-09-2011 | 12:31 AM
wray's Avatar
wray
Stage II
thanks Gunny I think I will change oil in the forks and bearings in triple tree and races and while I am at it wheel bearings are in order bike has 59900 miles on it. Bike has been lowered front and back. Shocks appear to be in good shape holding 35 lbs every thing was tight when I checked. had outer fairing and ingnition fairing off. just looking for suggestions.
Old 04-10-2011 | 11:53 AM
Ric27's Avatar
Ric27
Is it a wobble that comes on at a specific speed like 45-50 or does it just get worse the faster you go? At specific speed could be wheel/tire balance. 60k a lot of thing have had a chance to wear as well. good luck
R
Old 04-11-2011 | 01:31 PM
46u's Avatar
46u
What year and model bike? How many miles on it? Many years ago I was working on a old shovel FLH that had a front end wobble. I changed the neck bearings wheel bearings and fork oil and still had a front end wobble. Come to find out the swing are bearing where bad. Replaced them and wobble was gone.
nb472
09-25-2018 07:17 PM
94softailalan
10-30-2016 04:02 PM
Wrenchy
06-15-2015 03:24 PM
scoty
05-12-2014 05:41 PM
csd4682
Ironhead
17
07-06-2008 10:01 PM
