Too tight? sotail shock
07-21-2010, 06:53 PM
I have an 02 softail classic that I had to remove a shock. I bolted the shock back on to the frame and the washer, by the bolt head, which used to spin freely does not spin freely now. Do I need to back off the bolt a bit?
Thanks,
GEESE
07-21-2010, 09:14 PM
which bolt? The one in the front is torqued to ~35 ft-lbs and the one in the back about 135 ft-lbs. I don't think there is a washer spin spec.
07-22-2010, 10:27 AM
The back bolt (rear tire side) that holds the shock on. My bolts have a washer on them.
GEESE
07-25-2010, 09:34 AM
yes, so do mine. I believe the correct torque on those bolts is more important than a spinning washer.
sledgeb1
04-30-2023 03:01 AM
CrackHeadBob
05-08-2016 10:44 PM
markkoby
07-31-2015 03:37 AM
m i k e
09-10-2011 09:29 AM
amfhd
05-26-2008 09:49 PM
