Steering Head Leaking...
Hi All,
I hope this doesn't belong in "oil-related topics"...here goes: I bought a new '05 FXSTBI in Vivid Black this spring and before I took delivery, I had my dealer install black sliders, triple trees, brake rotors, and 6-spoke wheels. So basically, they had the whole front end apart. I've ridden the bike about a dozen times now and it has 900 miles on it. The problem is that every time I come back from a ride, I find that gobs of grease/oil have been oozing out of the bottom of the steering head into the air stream and onto the front valve cover, gas tank, my pants, etc. The lighter, oily component of this stuff also drips from the bottom bearing of the steering head onto the garage floor while the bike is parked. The "grease" is a very light brown color and of a very smooth/light texture. Question: did the "technicians" at my dealer fill my steering head with used K-Y jelly, or is this really the correct stuff? I mean, this can not be a normal condition, can it? EVERYONE would be complaining if this was the case. It's really corking my butt because the bike is absolutely fluid-tight in all other respects, as was my last bike (an '87 FXRS-SP). The service manual says to pump H-D "general purpose" grease into the Zerk fitting until it oozes out both the top and bottom bearings every 5000 miles. I checked out some new bikes in showrooms and the grease that is visable at the lower bearings appears to be of a slightly fibrous nature, so I'm hoping I'll be able to flush the snot out of there by chasing it out with the correct (different?) grease. I know that sooner or later it will quit coming out; it has to. I'm just affraid I'll be starting the whole process all over again when I grease it at 5000 miles. Anyone know anything about this problem?
Thanks
Thanks
RE: Steering Head Leaking...
The steering head grease that Harley dealers use and sell is blue in color. Sounds like you might have either the grease from the factory that is very sparse and thin....or they put in the wrong grease...if it ain't blue you might want to check back with them.
ORIGINAL: pilot1996
Another question...does it SMELL like used K-Y Jelly?
dchoran
07-20-2007 08:58 PM
