Having some issues with the front caliper, I think. Changed the brake pads and after mounting the calipers back on I have some play in the caliper at the lower mounting pin. When I apply the brakes I can see the caliper moving outwards, its not allot of movement but I can defiantly see it moving. Is the normal or should I pull it off and try remounting it again? Thanks
