Replacing fork oil in a 99 ultra air front suspension
03-19-2010, 09:28 AM
I just drained the old oil from my 99 flh forks and replaced the drain screws. I pulled the banjo fittings from both tubes up top and am trying to put the oil in, my shop manual just says fill with 287 mil of fork oil got some belray 20 and put the tube of the funnel down about an 1/2 inch and the fork wont take the oil its burping it up . any suggestions would be appreciated .
03-19-2010, 10:42 AM
You need to pump your forks to get the fluid down. Bounce your bike up and down.
03-19-2010, 08:58 PM
Thanks Bamm Bamm sounds like a great idea .
03-21-2010, 04:20 PM
If I remember right; you drain it out the bottom drain hole and then suck new fluid back up the drain hole using a brake bleed pump on the other end.
03-21-2010, 04:41 PM
Thanks Orbiker, that makes sense . I will try it.
03-23-2010, 12:10 PM
Thanks again Orbiker ! the vacuum idea worked great just filled them this morning
sB43
EVO
04-15-2019 05:43 PM
Harley-Davidson
EVO
05-10-2016 03:52 PM
WP50
EVO
13
10-18-2011 12:26 PM
tjjung
EVO
02-08-2007 02:29 PM
ultrapower
08-23-2006 08:26 PM
99 ,
air ,
capacity ,
changing ,
davidson ,
flh ,
fork ,
forks ,
front ,
harley ,
oil ,
ride ,
suspension ,
tool ,
ultra
