Was wondering if anyone knows what happening here i installed braided front brake line bled the brakes they work fine but at the caliper right were the line joins the banjo fitting the brake line has a teflon sleeve were the metal couple meets the brakleline there is brake fluid leaking inside the between the braided line and the teflon but were it joins to the banjo fitting its dry!! thought if the line is leaking it would be at the fitting?Thanks
