Ricor Intimidators 41 MM install
Hello,
Just wondering if anyone has installed a pair of the Ricir Intimidator front fork valve units?
I got some for my 2007 FLSTF this Christmas for myself, and my indy will not install them because I did not buy them through him- sucks.
So I think I may have to wrench this myself- do not want to screw up- so asking for advice if anyone else has done this on their halrey.
Thanks
Mark
Thanks
Mark
Hello,
Thanks
Mark
Thanks
Mark
Check out Mud's links. Install with pictures.
https://www.hdforums.com/forum/dyna-...n-upgrade.html
Hal
It's a piece-o-cake job. The forks do not need to come apart. Just pull fork out, unscrew top, pull spring, drain fluid, drop in Intiminator and spring, fill with Amsoil 5 wt shock oil, put top back on, install forks, wheel, fender, brake. Done!
I'm running a set in my 99 FLHT and really like 'em. They do what they are supposed to do. Couple these with a good set of rear shocks and it transforms an HD. They are going in the NT front end as soon as I PC the lower legs.
Longshot USMC
07-07-2014 11:09 AM
