wheel bearings
wheel bearings
Is the shop manual correct in telling me the left side has spacer washer,
without removing my bearings on my front wheel 2009 streetglide with abs, i'm hoping someone will chime in and tell what's in there. the shop manual says the left side has a spacer washer, standard bearing, abs encoder bearing. right side has spacer sleeve, standard bearing. My wheel is cast. picture in manual shows a laced wheel.
