Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Did I put in to much fork oil?
Old 01-22-2010 | 09:50 PM
ubreal's Avatar
ubreal
Default Did I put in to much fork oil?
I change out my fork springs to progressive lowered springs the manual said to put in 328 ml. Then use a special tool to get the oil level at 5.24 inch from the top of the fork tube to the top of the oil. Since I do not have this tool I use a ruler to check the distance. The oil was a little low I had to add about 25 ml to each fork. Does this sound about right I have never done this before and I do not want to screw anything up.
Old 01-22-2010 | 10:16 PM
qtrracer's Avatar
qtrracer
The oil level is the most important number. Legs collapsed and vertical , no springs installed. 5 and a quarter inches sounds good. Used a turkey baster with copper tubing shoved in the end back in the day to do my race bikes.
65Tiger
07-15-2018 10:15 AM
jimbo285
EVO
05-07-2014 11:09 AM
1forrest1
04-30-2013 10:44 AM
roaddr
12-19-2012 03:05 PM
ubreal
01-22-2010 11:10 PM
Quick Reply: Did I put in to much fork oil?
