Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Rear pully bolt torque specs for 03 Dyna needed
Old 05-29-2006, 05:30 PM
flats4u's Avatar
flats4u
flats4u is offline
Stage II
Default Rear pully bolt torque specs for 03 Dyna needed
I have an 03 Dyna Superglide and need the torque specs for the 5 bolts that mount the belt pully to the rear wheel. I tried using chrome bolts to mount the pully and just had 3 of them snap off so I am reverting back to the original OEM bolts and wanted to make sure they weren't over tightened. Also, is it a good idea to use locktite on these bolts to keep them from loosening
Old 05-31-2006, 01:22 AM
tripl8's Avatar
tripl8
tripl8 is offline
Default RE: Rear pully bolt torque specs for 03 Dyna needed
65 i think. Got a manual?
Old 05-31-2006, 12:46 PM
fxstcguy98's Avatar
fxstcguy98
fxstcguy98 is offline
You should use red loctite on them. Make sure the bolts that you are replacing have the same grade and they should work fine (either grade 5 or 8 I can't remember which, the markings on the head will tell you).
Old 05-31-2006, 08:54 PM
tripl8's Avatar
tripl8
tripl8 is offline
I,d stay with the Blue Loc-Tite..use red and you,ll regret it..thats all i,ve ever used and no problems...its still hard to remove them later .
Old 06-01-2006, 04:16 PM
piniongear's Avatar
piniongear
piniongear is offline
I will read to you directly from the factory manual:Two drops of Loctite 262 (red) on each of the 5 bolts. Uses washers with these bolts.
Torque for cast wheels= 55 to 65 ft lbs.
Torque for laced wheels= 45 to 55 ft lbs.
Additionally, these bolts are 7/16-14 x 2 1/4 Hex head w/ locking cap__Grade 5__Part # 3737A
Old 06-01-2006, 07:56 PM
tripl8's Avatar
tripl8
tripl8 is offline
The Manuals been wrong since Panheads...but do what you want.
Old 06-01-2006, 08:01 PM
piniongear's Avatar
piniongear
Well I am dumber than dirt and don't know any different, so I have no choice but to read and follow the manual. Wrong since Panheads huh? Now where have I heard that before?
Old 06-01-2006, 08:07 PM
tripl8's Avatar
tripl8
tripl8 is offline
Tell ya what ,man...go ahead an do what the Manual says..and when you want to change it out next time..and you break the bolts..use a torch and melt the Red LocTite first...that way you wont break anything..........................OR!...use Blu LocTite and forget it....but no matter what you do...do it your way.
Old 06-01-2006, 09:59 PM
piniongear's Avatar
piniongear
After reading your last post I went out to the shop and removed one bolt on the pully from my 2003 Dyna. It came out using just a little force, and guess what color the MoCo used for thread locker. That's correct...RED. So, maybe the factory does not read what they write, but I will follow the manual(s) thank you.
Old 06-01-2006, 10:03 PM
tripl8's Avatar
tripl8
tripl8 is offline
The FACTORY uses a white form of Loc-Tite....
Quick Reply: Rear pully bolt torque specs for 03 Dyna needed
