Standard Wide Glide forks are 41mm. On the new Dyna's the forks are 49mm on mid glide trees. Does anyone make wide glide trees for the 49mm forks that'll fit a FXST(B)?
I think they would look good on Softail's or Dyna's.
I wish that were true. I've got a 2007 and they have the 41mm.
The beefier 49mm really looks good. I just wish someone made the trees for them.
I purchased a set of fork tubes HD PN # 46617-06. They are 49 mm and they are for a 06-08 FXD/FXDWG (06-FXDWG). HEREHERE is an aftermarket companys who is advertising the wrong measurement of 27.5” but the correct numbers are Stock 27.913"/709mm that I measured ; 46617-06. You may work backwards and call your local HD shop and ask what bike these fit. This is the correct # as I bought them from HD and I measured them..
There are several of our members who purchased wide Glide Forks & put them on their Dyna HERE
No problem. I am glad it helped. Also look on Ebay . Look up ( harley 49mm triple tree ) I was just looking for a couple of parts for myself and checked 49 mm triple trees.
I think if you want to retro fit your Night Train? you would also need a front axle, bearings, distance collar, axle spacers, and front fender in addition to the triple tree's. I have been told (and don't know this to be fact) the 49mm front end will bolt on to 41mm equipped Dyna, you will however loose your steering lock function.
