Can I replace my bearings with sealed? 1991 FLSTC
RE: Can I replace my bearings with sealed? 1991 FLSTC
Are the front and rear bearing size both 1"?
I found the on the Bay
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Might just have to try them...
Simple. CCI, Drag, Jireh Cycles, JP and more carry a retrofit kit for all 99 and below wheels. Kit comes with two bearings you can press right in. You can even buy the kit with a new bearing spacer tube as well. Much cheaper and less hassle then dealing with races, bearings, seals, spacers and end play. If you need a part number let me know. www.chromethathog.com
[IMG]local://upfiles/15359/B4975FF4F65A4D9A867198A0B49BAD67.jpg[/IMG]
