fork oil with lowering kit
Brian
Brian
Distance from Top
I have no idea what the distance should be on your setup but the standard, as mentioned earlier, is to set the oil at a certain distance from the top. This should be done after working the forks up and down to work all air out.
The "Tuning" that was mentioned basically works on the principal that the Air that is within the fork is getting compressed as your fork compresses. The less air space (Higher the Oil) there is will make the fork stiffer as you reach fuller compression of the fork. At very light strokes/bumps, say first halve of travel there is little effect from a higher oil level. The viscosity of the oil itself and the spring are controlling the dampening.
Bottom line is find out what the correct level is (the people that sold you the lowering kit should know) and then if you are a bit aggressive or ride on bad roads frequently or are on the heavy side then you might want to put in just a bit more oil.......... only a 1/4"-3/8" at most though.
Get a LARGE syringe to suck it out.... they are usually sold at a Motorcycle shop that does a lot of Dirt Bike work for a few buck.
Might be able to use the wifes deal she uses for basting turkeys.... make sure you throw it away afterwards
